Buffalo 4TB (1 x 4TB) LinkStation 210 1-Bay NAS
£142.74
Select:
15 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Sorry NSA - the truly private cloud
  • Organize your life
  • Powerful backup NovaBACKUP
  • Built-in BitTorrent
  • Quick and easy setup
  • Direct Stream Digital (DSD)
  • Gigabit Ethernet port 10/100/1000
  • Restricted network access
  • Seamlessly Wired to iTunes
  • Active Directory support
  • Capacity: 4TB
  • Interface: Ethernet, Fast Ethernet, Gigabit Ethernet
  • Type: 1-Bay
  • Stock Status: In Stock
Product codes
Buffalo Technology's LinkStation 210D series makes sure you have all your data in a central place and can access it from anywhere in the world. The LS210 combines the convenience and capacity of Network Attached Storage with an incredibly easy User Interface and super-quiet fan-less operation. It is fast and ready for intensive data storage tasks and can even be set up via Smartphones with a mobile-optimized and intuitive interface. Buffalo Technology's LS210 series is a single bay Network Attached Storage available fully populated with big capacity.
Product Description BUFFALO LinkStation 210 - NAS server - 4 TB
Device Type NAS server
Host Connectivity Gigabit Ethernet
Total Storage Capacity 4 TB
Dimensions (WxDxH) 4.5 cm x 20.5 cm x 12.8 cm
Weight 1.1 kg
Processor 1 x Marvell ARMADA 370 800 MHz (Dual-Core)
Storage Controller SATA SATA 3Gb/s
Hard Drive 1 x 4 TB SATA 3Gb/s
Networking 10Mb LAN, 100Mb LAN, GigE
RAM 256 MB
Power AC 120/230 V (50/60 Hz)
System Requirements Microsoft Windows XP, Apple MacOS X 10.6 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8, Microsoft Windows RT, Android 2.3 or later, Apple iOS 5.0 or later, Windows 8.1 (32/64 bits), Windows 8.1 RT
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Buffalo 4TB (1 x 4TB)...
£142.74
