Buffalo 500GB MiniStation Extreme Water&Dust Resistant US...
Buffalo 500GB MiniStation Extreme Water&Dust Resistant USB 3.0
£67.48
Delivery:
Standard: 1-3 working days
Key features
  • US military grade (MIL-SPEC) shock protection
  • Flex connect USB cable
  • Hardware disk encryption
  • Compact and sleek
  • USB powered
  • Connect and go
  • Buffalo tools
  • Back up your files
  • Time Machine compatibility
  • Eco manager
Product codes
BUFFALO's MiniStation Extreme offers high performance USB 3.0 portable storage in a compact and sophisticated design. The internal hard drive is encased in a highly shock-resistant body with rubberized elements to protect it from accidental bumps. The USB cable is integrated with the case so you will not be frustrated searching for a cable anymore! The USB 3.0 interface moves data at rates of up to 5Gbps. This vastly reduces the time needed for data transmission, making it ideal for transferring and sharing videos, large digital photo collections, music files, and other data-intensive digital content.
Product Description BUFFALO MiniStation Extreme HD-PZF500U3B-EU - hard drive - 500 GB - USB 3.0
Type Hard drive - external (portable)
Capacity 500 GB
Hardware Encryption Yes
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Features Shock resistant, Hardware Full Disk Encryption (FDE), rugged, wrap-around USB cable, Apple Time Machine compatible, 256-bit AES
Power Source USB bus
Enclosure Colour Black
Dimensions (WxDxH) 90 mm x 21 mm x 141 mm
Weight 277 g
Manufacturer Warranty 2 years warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Buffalo 500GB MiniStat...
£67.48
