Buffalo DriveStation Duo 8TB USB 3.0
£519.87
Select:
Delivery:
Key features
  • Quick swap - 2-drive, 2-bay Direct Attached Storage (DAS)
  • 10x faster than USB 2.0 - perfect for backing up large servers or multimedia files
  • Backwards compatible with USB 2.0
  • Supports RAID 0, 1 and standard
  • Removable front panel - to quickly and easily replace faulty drives
  • Multiple connectivity with 5 Gbps USB 3.0 and 480 Mbps USB 2.0 connections
  • Easy to use - simply plug and play - no drivers required
  • Drive pre-formatted for immediate use
  • Eco-friendly - AutoPower feature turns the drive on and off with your PC
Product codes
The Buffalo DriveStation Duo USB 3.0 is a high performance, multimedia, external hard drive perfect for the home or small office that requires large amounts of storage space. The unit is a two-drive; two-bay RAID enabled drive with RAID 0 for performance and RAID 1 for redundant storage. The DriveStation Duo gives additional storage to quickly backup all your multimedia files.
The DriveStation Duo USB 3.0 features the capacity, redundancy and performance required for any demanding user, the perfect solution for backing up large servers or multimedia files.
Product Description BUFFALO DriveStation Duo USB 3.0 - hard drive array
Device Type Hard drive array
Total Array Capacity 8 TB
Interface USB 3.0
Installed Devices / Modules Qty 2 (installed) / 2 (max)
Supported Drives SATA-300
Storage Controller RAID (SATA 3Gb/s) - RAID 0, 1
Hard Drive 2 x 4 TB HDD SATA 3Gb/s
OS Required Microsoft Windows XP, Microsoft Windows Server 2003, Apple MacOS X 10.4 or later, Microsoft Windows Server 2003 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2008 R2 (64-bits)
Power AC 120/230 V - 50/60 Hz
Dimensions (WxDxH) 8.6 cm x 20.4 cm x 12.7 cm
Weight 2 kg
Manufacturer Warranty 2 years warranty
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Buffalo DriveStation D...
£519.87
