Buffalo DriveStation Velocity 6TB USB3.0 7200rpm External HDD
£145.64
Delivery:
Standard: 1-3 working days
Key features
  • SuperSpeed USB 3.0
  • TurboPC EX utility
  • High speed 7,200 rpm hard disk
  • Hardware disk encryption
  • Back up your files
  • RAMDISK virtual disk utility
  • Plug and Play connectivity
  • Fully backwards compatible with USB 2.0
  • Form Factor: 3.5"
  • Capacity: 6TB
  • Interface: USB 3.0
  • Stock Status: In Stock
Product codes
DriveStation Velocity is the perfect solution for those who need to transfer files quickly and easily. The amazing speed performance comes from a combination of a more efficient improved USB 3.0 interface, Buffalo's enhanced TurboPC EX data transfer and copy utility and a 7,200 rpm drive. If you haven't moved up to USB 3.0 yet - DriveStation Velocity is backward compatible with USB 2.0.
The unit is also optimal for users who want to restrict access to their personal drive when on a shared computer or network. Powerful yet easy-to-use security options include automatic hardware encryption that protects your data, with no loss of performance.
Product Description BUFFALO DriveStation Velocity - hard drive - 6 TB - USB 3.0
Type Hard drive - external (desktop) - Hardware Full Disk Encryption (FDE), automatic backup, ECO, cooling fan, power management support
Capacity 6 TB
Hardware Encryption Yes
Interface USB 3.0
Data Transfer Rate 5.0 Gbps (USB 3.0)
Spindle Speed 7200 rpm
Features Hardware Full Disk Encryption (FDE), automatic backup, ECO, cooling fan, power management support, 256-bit AES
Dimensions (WxDxH) 3.9 cm x 18.9 cm x 12.3 cm
Weight 950 g
Localisation Europe
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Buffalo DriveStation V...
£145.64
