Buffalo TeraStation 5200 WS5220DN08W6EU 8TB (2 x 4TB WD Red) TAS
£1,164.16
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • No CAL (Client-Access Licenses) required
  • Cost-effective storage solution to make full use of existing Windows-based environments
  • 10 GbE/Dual Core CPU with 8GB DDR4 ECC memory
  • A variety of backup features [DFS Replication, Shadow Copies/Azure Backup]
  • Highly secured with the latest SMB protocol support (3.1.1)
  • Capacity: 8TB
  • Interface: 10 Gigabit Ethernet, 2.5 Gigabit Ethernet, 5 Gigabit Ethernet, Ethernet + 2 more
  • Stock Status: In Stock
Product codes
TeraStation WS5020N6 series is a high-performance network attached storage with the power and convenience of Windows operating system. TeraStation WS5020N6 series features native 10GbE connectivity and achieves increased reliability by populating with hard drives built specifically for always-on NAS devices.
The WS5020N6 seamlessly melds with networks' existing Windows computers and server enabling quick straightforward deployment and massive storage capacity available in an instant. WS5020N6 is an ideal solution for consolidating multiple file servers into a single solution that enables cost reduction and lowering of the overhead on your existing servers for other workloads.
Once deployed, users will find WS5020N6 enables full Active Directory integration facilitating comprehensive access management, policies, and security. This allows networks to automate access and manage storage in the same way as they do their Windows Server. PowerShell and Microsoft Systems Center are ready-to-use, as well as a flexible choice of storage protocols (iSCSI, CIFS/SMB, NFS). Your most demanding applications and processes, such as replication, SQL, a fast-indexing search during an anti-virus scan, and more, are no problem for the WS5020N6.
Product Description BUFFALO TeraStation WS5020N6 Series WS5220DN08W6EU - NAS server - 8 TB
Device Type NAS server
Host Connectivity Gigabit Ethernet / 10 Gigabit Ethernet
Total Storage Capacity 8 TB
Dimensions (WxDxH) 17 cm x 23 cm x 17 cm
Weight 5 kg
Processor 1 x Intel Atom C3338 (Dual-Core)
Storage Controller RAID SATA 6Gb/s - RAID 1, JBOD
Hard Drive 2 x 4 TB SATA 6Gb/s
Networking 10Mb LAN, 100Mb LAN, GigE, 10 GigE, 5 GigE, 2.5 GigE
RAM 8 GB
Power AC 120/230 V (50/60 Hz)
Storage Operating System Microsoft Windows Storage Server 2016 Workgroup
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Server 2008, Microsoft Windows 7 (32/64 bits), Microsoft Windows Server 2012, Windows 8.1 (32/64 bits), Microsoft Windows Server 2012 R2, Windows 10, Microsoft Windows Server 2016, Apple MacOS X 10.11 - 10.13
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Buffalo TeraStation 52...
£1,164.16
