Buffalo Wireless N900 Gigabit Dual Band Router
Key features
  • The WZR-900DHP-EU is primed and ready-to-go with simultaneous transfer speeds of up to 450MBps in both the 5GHz and 2.4GHz bandwidths; and managing two networks at the same time splits the workload for noticeably better performance
  • With four gigabit LAN ports and one gigabit WAN the WZR-900DHP-EU offer ultra-fast wired connections. Speeds can be up to 10× faster than standard Ethernet connection. Together with an USB3.0 port it is extremely versatile
  • The Buffalo AirStation One-Touch Secure System (AOSS), Wi-Fi Protected Setup (WPS) and the new intuitive interface provide a quick and easy way to create a secure wireless connection to a host within minutes
  • The WZR-900DHP-EU also comes with USB 3.0 port, media server, device server, and BitTorrent for easy file sharing across connected devices
  • The AirStation Dual Band Gigabit router also offers Norton ConnectSafe that defends your network and family against unsafe or undesirable websites. It’s a basic security that blocks access to problem sites and automatically protects your device against phishing and malware sites. Content from 30 categories is blocked while you keep the ability to always allow certain sites or make exceptions for single clients
  • Media server, device server, and BitTorrent for easy file sharing across connected devices
Product codes
Buffalo's new AirStation Dual Band Gigabit router (WZR-900DHP-EU) brings a new fast and versatile dual band solution to Buffalo's family of wireless routers. The WZR-900DHP-EU is primed and ready-to-go with simultaneous transfer speeds of up to 450MBps in both the 5GHz and 2.4GHz bandwidths; and managing two networks at the same time splits the workload for noticeably better performance.
The 5GHz band is ideal for faster, uninterrupted HD video streaming and concurrent Internet access for new mobile phones, tablets, and laptops. And your other devices will also benefit from the new AirStation's simultaneous fast transfer speeds in the 2.4GHz bandwidth.
The WZR-900DHP-EU also comes with USB 3.0 port, media server, device server, and BitTorrent for easy file sharing across connected devices. Additional advanced features such as QoS (Quality of Service) allow users to prioritize router traffic by type - the higher the priority, the higher the allocated bandwidth thereby helping ensure consistent performance across all your applications, and especially for your preferred applications.
Upgrade your existing wireless connection to provide greater coverage and fast transfer speeds: Buffalo's WZR-900DHP-EU is the next generation of wireless connectivity.
BUFFALO AirStation WZR-900DHP - wireless router - 802.11a/b/g/n - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
450 Mbps
NAT support, auto-uplink (auto MDI/MDI-X), packet filtering, Intrusion Detection System (IDS), MAC address filtering, VPN passthrough, parental control, Airstation OneTouch Secure System (AOSS), MIMO technology, Quality of Service (QoS), Wi-Fi Protected Setup (WPS), port forwarding, BitTorrent Client, Stateful Packet Inspection Firewall (SPIF), Direct Sequence Spread Spectrum (DSSS)
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, Wi-Fi CERTIFIED, USB 2.0, IEEE 802.11n, USB 3.0
2.8 cm x 18.5 cm x 20 cm
520 g
Microsoft Windows XP, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Windows 8 (32/64 bits), Apple MacOS X 10.4 - 10.8
Customer reviews
Accessories
Network Adaptors
Other bundles
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
Buffalo Wireless N900...
