C2G .5m Pro-Audio XLR M To XLR F
£7.23
44 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Made from twisted-pair audio cable under an aluminum foil for maximum shielding from noise
  • 22AWG twisted-pair construction
  • Foil shield and 60% copper braid
  • Nickel plated brass connectors
  • Type: Audio
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Pro-Audio cables from C2G are perfect for connecting line or mic level outputs from mixing consoles to recorders and amplifiers with balanced inputs. Highly flexible, 7mm PVC jacket reduces the risk of cables kinking and damaging the conductors. Bright nickel plating on solid brass connectors resists wear from reconfiguring and moving equipment from one venue to another. Chuck strain relief inside the XLR connector reduces the effects of age on the solder joints and contacts.
Product Description C2G Pro-Audio audio cable - 50 cm
Cable Audio cable
Technology Shielded foiled twisted pair (SFTP)
American Wire Gauge (AWG) 22
Length 50 cm
Connector XLR3 - male
Connector (Second End) XLR3 - female
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G .5m Pro-Audio XLR...
£7.23
