C2G .5m VGA270™ HD15 UXGA M/F Monitor Extension Cable
£6.52
12 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Rotating 270° connectors on each end move side-to-side in almost a complete circle!
  • Type: VGA
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Bring ultimate flexibility to your video applications with the patent-pending VGA270 UXGA monitor cables bY-C2G. The HD connectors on each end rotate from side-to-side in almost a complete circle, allowing you to position the cable to fit your installation. The connectors feature detents, or "click-stops", ensuring signal integrity is maintained. These premium UXGA cables are ideal for connecting video equipment such as projectors, video splitters, monitors and KVMs. With VGA270, the days of not having the right connector orientation on your cables are over!
Product Description C2G VGA270 UXGA Monitor Extension Cable - VGA extension cable - 50 cm
Type VGA extension cable
Technology Shielded
Features Thumbscrews
Length 50 cm
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - female
Compliant Standards RoHS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G .5m VGA270™ HD15 U...
£6.52
