C2G 0.5m Select High Speed HDMI with Ethernet
£7.70
Delivery:
Standard: 1-3 working days
Key features
  • Deliver high definition video, audio and Ethernet using a single, in-wall rated cable
  • Foil Shield - Aluminium Foil, 125% Coverage
  • • Braided Shield - 16/10/0.12, CCAM
  • • Jacket - PVC (UL/CL2), Black, O.D. - 7.3 ± 0.2mm
  • Type: HDMI
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Experience ULTRA HD (4K) displays with this Select High-Speed HDMI Cable which provides a fast and reliable connection for home theatre or desktop audio video applications requiring high speed HDMI capabilities and video resolutions up to 4K (2160p). This High-Speed HDMI Cable supports the latest HDMI features including Ultra HD, 4K at 50/60 (2160p), up to 32 audio channels and wide angle theatrical 21:9 video aspect ratio and is compatible with any modern Laptop, Chromebook, HDTV or gaming console, including Sony PlayStation 4 (PS4) and Microsoft Xbox ONE. The cable is also backwards compatible with PlayStation 3 (PS3) and Xbox 360. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable allow users to connect multiple Ethernet-enabled HDMI devices through a single Ethernet connection. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty. Note: Both the source device and display must support a HDMI feature in order to pass that particular feature through this cable.
Product Description C2G 0.5m Select High Speed HDMI Cable with Ethernet - 4K - UltraHD - HDMI with Ethernet cable - 50 cm
Cable HDMI with Ethernet cable
Technology Shielded
American Wire Gauge (AWG) 28
Length 50 cm
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 0.5m Select High S...
£7.70
