C2G 0.5m Thunderbolt 3V Cable (40GBPS) 50cm
£29.56
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Deliver 4K video, data content at 40Gbps, and power between Thunderbolt 3 devices
  • Supports a top data transfer speed of 40Gbps when connected to Thunderbolt 3 devices
  • 8x faster than USB 3.0 and 4x more video bandwidth than HDMI
  • Thunderbolt, USB and DisplayPort backward compatible
  • Supports two 4K 60Hz displays (4096 x 2160 30bpp @ 60 Hz)
  • Capable of charging and syncing USB-C mobile devices
  • Thunderbolt Networking allows 10Gb Ethernet connection between computers
  • Daisy-chain up to six devices
Product codes
Thunderbolt 3 brings lightning speed data transfer, dual 4K video support, high bit depth audio, and power delivery up to 100W. Get more done with less hassle by carrying one cable to complete nearly any task.
Deliver up to 40Gbps to or from a Thunderbolt 3 enabled port. Whether uploading or downloading data, this cable is an ideal solution to transfer large amounts of information such as high resolution photos for editing or storage, 3D models for video game authoring, or HD video for editing. Capable of backing up a year’s worth of continuous MP3s in five minutes!
Ensure that a Thunderbolt 3 equipped laptop, smartphone, or tablet is fully charged and ready to go while displaying video content, transferring files, or streaming audio. Deliver up to 100W of charging power to or from the connected device with smart power delivery. The Thunderbolt 3 cable offers a light-weight, portable, and simple way to deliver video, and data—while staying charged up!
The USB-C connector has a robust design, allowing for the connector to be plugged in and un-plugged up to 10,000 times. The sturdy construction ensures that the product provides peace of mind and is built to stand up to the rigors the most demanding on-the-go life. The USB-C connector has a symmetrical design which is identical on both sides, so it does not matter if you plug it in upside-down or right-side-up. It will plug in the first time, every time while preventing damage to the connector port.
C2G 0.5M Thunderbolt 3 cable (40Gbps) - Thunderbolt cable - 50 cm
Thunderbolt cable
4K support, sync and charge
Length
50 cm
Connector
24 pin USB-C - male
Connector (Second End)
24 pin USB-C - male
Rated Voltage
30 V
Thunderbolt 3
3 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 0.5m Thunderbolt 3...
£29.56
