C2G 0.5m UK Laptop Power Cord (BS 1363 to IEC 60320 C5)
£4.58
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Replacement power cord for many laptops
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Replace your overused or misplaced power cable, or just get some extra cords for convenience. This power cord is designed to work with laptops that use a 3-slot power cord. This 18 AWG cord features a fully moulded design for maximum durability and long life. The female connector, often called a Clover Leaf connector, plugs directly into the device while the male connector plugs into a standard outlet.
Product Description C2G Laptop Power Cord - power cable - 50 cm
Type Power cable
Features Molded
Length 50 cm
Localisation United Kingdom
Connector Power IEC 60320 C5
Connector (Second End) Power BS 1363 - male
Rated Voltage AC 250 V
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 0.5m UK Laptop Pow...
£4.58
