C2G 0.5m Velocity DB9 Male to 3.5mm Male Adapter
£9.18
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Please Note: Not all serial control methods are supported by this adapter. This product is intended only for use with 3-wire RS-232 control cables with common ground (pin 5), transmit data (pin 3), and receive data (pin 2). For the exact pin-out of your audio/video equipment, please contact your RapidRun sales representative for assistance, or call customer service at 0800 328 2916 or +44(0)1952 677300 from outside the UK
  • Adapt your 3.5mm stereo jack for RS-232 serial control
  • Pin-out:
  • • DB9 Pin 3 to 3.5mm Tip
  • • DB9 Pin 2 to 3.5mm Ring
  • • DB9 Pin 5 to 3.5mm Sleeve
  • Length: 50cm
  • Stock Status: In Stock
Product codes
Why run cables for RS-232 control of your audio/video system, when you can use this easy adapter? The Velocity RS-232 adapter leverages your DB9 or 3.5 mm stereo audio cable to run 3-conductor RS-232 control signals between your control unit and your video display. Fully molded DB9 and 3.5 mm connectors provide excellent strain relief. This adapter is ideal for use with computers, projectors, and any control unit/display requiring 3-conductor RS-232 serial control.
Product Description C2G Velocity DB9 Male to 3.5mm Male Adapter Cable - serial cable - 50 cm
Type Serial cable
Features Molded, thumbscrews, strain relief
Length 50 cm
Connector Mini-phone stereo 3.5 mm - male
Connector (Second End) 9 pin D-Sub (DB-9) - male
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 0.5m Velocity DB9...
£9.18
