Experience 4K ULTRA HD displays with this USB-C to HDMI Adapter Cable which provides a fast and reliable connection between a USB Type C enabled Chromebook, laptop, tablet or other device and an HDTV, projector or other HDMI-equipped display – making it an ideal solution for the office, work space applications or home use. Supporting resolutions up to 4K @ 60Hz, which is four times the clarity of 1080p, this cable offers high quality, ULTRA HD video image. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The cable form factor of this adapter provides a simple and convenient one-cable solution that eliminates the need for a separate adapter or additional cabling.
Product Description | C2G 0.9m (3ft) USB C to HDMI Adapter Cable 4K - Audio / Video Adapter - Black - external video adapter - black | Device Type | External video adapter | Bus Type | USB-C | Max Resolution | 3840 x 2160 | Interfaces | HDMI (male connector) | Length | 90 cm | Enclosure Colour | Black | Manufacturer Warranty | 3-year warranty |
General | |
Bus Type | USB-C |
Max Resolution | 3840 x 2160 at 60 Hz |
Miscellaneous | |
Compliant Standards | Plug and Play, RoHS 2 (2011/65/EU) |
Length | 90 cm |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Environmental Parameters | |
Min Operating Temperature | 0 °C |
Max Operating Temperature | 45 °C |
