C2G 0.9m (3ft) USB C to VGA Adapter Cable - Black
£42.42
Delivery:
Key features
  • Connect a USB Type-C device to the VGA port of a monitor or projector to display video
Product codes
The USB-C to VGA Adapter Cable provides a fast and reliable connection between a USB Type C enabled Chromebook, laptop, tablet or other device and a monitor, projector or other display with a VGA input – making it an ideal solution for the office, work space applications or home use. This adapter utilises the audio/video capabilities built into USB Type-C ports to feed a video signal to the connected display and supports up to a 1920x2100 at 60Hz resolution, allowing it to deliver a high-quality video image. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The cable form factor of this adapter provides a simple and convenient one-cable solution that eliminates the need for a separate adapter or additional cabling.
Product Description C2G 0.9m (3ft) USB C to VGA Adapter Cable - Video Adapter - Black - external video adapter - black
Device Type External video adapter
Bus Type USB-C
Max Resolution 1920 x 1200
Interfaces VGA (male connector)
Length 90 cm
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 0.9m (3ft) USB C t...
£42.42
