C2G 1.5m Cat5E 350 MHz Crossover Patch Cable - Red
£3.52
Delivery:
Key features
  • Use with a network adapter to network two Windows -based desktop PCs in a peer-to-peer, hub-to-hub, transceiver-to-transceiver or repeater-to-repeater networking configuration.
Product codes
This Cat5e network crossover patch cable is an ideal solution for connecting two computer to share files or data. The crossed pin configuration allows two computers to be connected peer-to-peer without the need for a hub or switch. This cable may also be used to connect network switches and hubs without an uplink port to other switches and hubs. This cable is constructed to meet all Cat5e TIA/EIA standards, and has been designed to drastically reduce both impedance and structural return loss (SRL). Each of the individual pairs is bonded together to help maintain the twist-spacing throughout the line right up to the termination point. Constructed from high quality cable and a shortened body plug, this design minimizes Near-End Crosstalk (NEXT) levels.
Product Description C2G Cat5e Non-Booted Unshielded (UTP) Network Crossover Patch Cable - crossover cable - 1.5 m - red
Type Crossover cable - CAT 5e
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Wires per Cable 8 wires
Features Stranded, uniboot
Length 1.5 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Red
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 1.5m Cat5E 350 MHz...
£3.52
