C2G 10m Select High Speed HDMI with Ethernet
£48.99
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Deliver high definition video, audio and Ethernet using a single, in-wall rated cable
  • Foil shield - aluminum foil, 125% coverage
  • Braided shield - 16/10/0.12, CCAM
  • Jacket - PVC (UL/CL2), black, O.D. - 7.3 ± 0.2mm
Product codes
The Select Standard Speed HDMI Cable provides a reliable connection up to a distance of 30 feet (10 metres) for home theatre, desktop and commercial audio video applications requiring standard speed HDMI capabilities and video resolutions up to 1080i. The CL2 rated cable jacket is designed to meet the requirements for in-wall installations. The Ethernet capabilities of the cable enable users to connect multiple Ethernet-enabled devices through a single Ethernet connection. This fully-functional cable is tested to perform at industry standards and backed by a lifetime warranty.
Product Description C2G 10m Select Standard Speed HDMI Cable with Ethernet - HDMI with Ethernet cable HDMI to HDMI - 10 m
Cable HDMI with Ethernet cable
Technology Shielded
American Wire Gauge (AWG) 28
Length 10 m
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 10m Select High Sp...
£48.99
