C2G 12m USB 2.0 A/A Active Extension Cable
£19.68
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Brilliant USB extension solution for PC & MAC users
  • Length: 12m
  • Stock Status: In Stock
Product codes
The TruLink USB 2.0 Active Extension Cable is perfect when you need extra distance; this cable will extend the reach of your USB 2.0 cable or device 12m (40'). The USB active extension cable actively buffers the incoming and outgoing signals to ensure compliance with the USB 2.0 specification for electrical and timing minimums. Both low and high speed USB devices will function equally well with this cable. Great for extending the reach to your USB devices.
Product Description C2G TruLink USB 2.0 Active Extension Cable - USB extension cable - 12 m
Type USB extension cable
Features Active cable (signal regeneration)
Length 12 m
Connector 4 pin USB Type A - female
Connector (Second End) 4 pin USB Type A - male
Compliant Standards USB / USB 2.0
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 12m USB 2.0 A/A Ac...
£19.68
