C2G 15cm Mini DisplayPort Male to DisplayPort Female Adapter...
C2G 15cm Mini DisplayPort Male to DisplayPort Female Adapter Cable -  Black
£9.60
Colours:
35 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Adapt the Mini DisplayPort output of a computer so that it may be connected to a computer monitor which accepts a DisplayPort input
  • Length: 15cm
  • Stock Status: In Stock
Product codes
This adapter converter is an ideal solution for adapting the Mini DisplayPort output of a small laptop or tablet so that it may be connected to a computer monitor which accepts a DisplayPort input. This adapter converter carries a digital audio/video signal and supports up to a 4k resolution and meets the requirements of high performance applications.
Product Description C2G 15cm Mini DisplayPort to DisplayPort Adapter Converter 4K UHD - Mini DP Male to DP Female - Black - DisplayPort cable - 15 cm
Type DisplayPort cable
Length 15 cm
Connector Mini DisplayPort - male
Connector (Second End) DisplayPort - female
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 15cm Mini DisplayP...
£9.60
