C2G 15cm Mobile Device USB Micro B to USB Device OTG Adapter Cab
£5.11
11 in stock
Delivery:
Standard: 1-3 working days
  • Length: 15cm
  • Stock Status: In Stock
Product codes
The 15 cm Mobile Device USB Micro-B to USB Device OTG adapter cable is the perfect solution for expanding the capabilities of an OTG enabled tablet, smartphone or other mobile device by directly connecting a USB device such as a USB flash drive for additional storage or a USB keyboard and mouse for additional control. Connect a USB hub to this adapter to further expand the capabilities of the mobile device by connecting multiple USB devices. USB OTG technology makes this connection easy and does not require a driver, software or lengthy setup time. Simply connect the adapter to the Micro-B port on an OTG enabled mobile device, connect the USB device directly to the USB A port on the adapter and the two devices are ready to be used together.
Product Description C2G Mobile Device USB Micro-B to USB Device OTG Adapter Cable - USB adapter - 15 cm
Type USB adapter
Technology Double shielded
Length 15 cm
Connector 4 pin USB Type A - male
Connector (Second End) 5 pin Micro-USB Type B - female
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 15cm Mobile Device...
£5.11
