C2G 15m Active Optical DisplayPort Cable CMP
£607.34
Select:
Delivery:
Key features
  • Colour
  • Connector 1
  • Connector 2
Product codes
The DisplayPort AOC is the perfect solution for extending DisplayPort signals in classrooms, conference rooms, healthcare facilities, digital signage and other commercial environments. [B]Convenience[/B].
Utilising AOC technology that performs similar to traditional copper cabling, the optical fibre construction between the connectors provides optimum performance and easy installation. The AOC technology delivers several advantages which make it a smart choice in select installations. The cable diametre is smaller than copper and more flexible, making it easier to install in tight spaces. Constructed from fibre strands, this cable reduces the risk of EMI/RFI so performance is stable when used in typically high interference environments such as data centres, surgical theatres, or manufacturing facilities where high resolution and consistent display are critical.
[B]Performance[/B].
The AOC draws power from the DisplayPort source device, so no external power source is required. In addition to low power consumption, these cables are also plug and play and hot swappable. Additionally, the DisplayPort Active Optical Cable supports the latest 4K60 content delivery over longer distances.
Product Description C2G 15m DisplayPort Active Optical Cable (AOC) - 4K UHD - Plenum CMP-Rated - DisplayPort cable - 15 m
Cable DisplayPort cable
Technology Fibre optic
Length 15 m
Colour Grey
Connector DisplayPort - male
Connector (Second End) DisplayPort - male
Compliant Standards DisplayPort 1.2
Features Plenum, 4K support
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 15m Active Optical...
£607.34
