C2G 1m 16AWG 250V 16 Amp Power Ext IEC 60320 C20-IEC 60320 C19
£8.14
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Extend the length of your power cord for more flexibility
  • Length: 1m
  • Stock Status: In Stock
Product codes
Make your work environment more flexible and efficient. This heavy duty 16 AWG cord is designed to work with PDUs, PSUs and other high power devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into another power cord, or auxiliary power port on power supply for auto power when the system is turned on.
Product Description C2G 16 AWG 250 Volt 16 Amp Power Extension Cord - power extension cable - 1 m
Type Power extension cable
Features Molded
Length 1 m
Connector Power IEC 60320 C20
Connector (Second End) Power IEC 60320 C19
Rated Voltage AC 250 V
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 1m 16AWG 250V 16 A...
£8.14
