C2G 1m DVI-D™ M/M Dual Link Digital Video Cable
£10.04
25 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High performance cable connects desktop PCs to flat panel displays, digital CRT displays, projectors and HDTV
  • Type: DVI
  • Length: 1m
  • Stock Status: In Stock
Product codes
This precision-engineered cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). The DVI-I single link configuration provides enough bandwidth for resolutions up to 2048 x 1536 pixels and allows high speed transmission up to 9.9 Gbps. Three analogue 30 AWG coaxial lines enable high speed analogue transmission.
Product Description C2G DVI cable - 1 m
Type DVI cable - dual link
Technology Triple shielded
Features Colour-coded connectors
Length 1 m
Connector DVI-D - male
Connector (Second End) DVI-D - male
Compliant Standards PC 99, RoHS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 1m DVI-D™ M/M Dual...
£10.04
