C2G 1m Pro-Audio 1/4in TRS Male to 1/4in TRS Male Cable
£6.68
Delivery:
Key features
  • Connector 1: (1) 1/4in TS Male
  • Connector 2: (1) 1/4in TS Male
  • Bright nickel plating on solid brass connectors resists wear
  • Spring strain relief reduces the effects of age on the solder joints and contacts
  • Type: Audio
  • Length: 1m
Product codes
Use this 1/4in to 1/4in cable to connect unbalanced line outputs to unbalanced line inputs. This pro-audio cable is made from 22 AWG twisted pair audio cable under an aluminium foil shield and 60% copper braid for maximum shielding from noise. The highly flexible 7mm PVC jacket reduces the risk of the cable kinking and damaging the conductors. Bright nickel plating on solid brass connectors resists wear from reconfiguring and moving equipment from one venue to another. Spring strain relief on the 1/4in plug reduces the effects of age on the solder joints and contacts.
Product Description C2G Pro-Audio audio cable - 1 m
Cable Audio cable
Technology Shielded foiled twisted pair (SFTP)
American Wire Gauge (AWG) 22
Length 1 m
Connector Stereo jack - male
Connector (Second End) Stereo jack - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 1m Pro-Audio 1/4in...
£6.68
