C2G 1m SC/SC LSZH Duplex 50/125 Multimode Fibre Patch Cable -...
C2G 1m SC/SC LSZH Duplex 50/125 Multimode Fibre Patch Cable - Orange
£10.18
Delivery:
Key features
  • Connector 1: (1) SC Male
Product codes
Cost-effective solution that provides higher bandwidth and transmission rates and supports longer distances with lower loss than 62.5/125 fibre. Specifically designed for use with today's narrower aperture components, this cable is fully compatible with multimode applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 50/125 multimode fibre, immune to electrical interference.
Product Description C2G Low-Smoke Zero-Halogen - patch cable - 1 m - orange
Type Patch cable
Technology Fibre optic
Type of Fibre Optics Multimode
Length 1 m
Core / Cladding Diameter 50 / 125 micron
Connector 2 x SC multi-mode - male
Connector (Second End) 2 x SC multi-mode - male
Colour Orange
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 1m SC/SC LSZH Dupl...
£10.18
