C2G 1m USB 2.0 A Right Angle Male to Micro-USB Right Angle Male
£5.07
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Connect your portable USB device to a micro-USB port on your computer or other USB device
  • Stock Status: In Stock
Product codes
Connect to mobile phones, GPS systems, PDAs, OTG devices and digital cameras by using the micro-USB connection on your computer or other USB device. The micro-USB connector is smaller and thinner than the previous USB Mini-b standard while offering better performance. Its small right angle form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a transfer speed up to 480 Mbps. This cable is compliant with USB 2.0 specifications and the On-The-Go supplement.
Product Description C2G USB 2.0 A Right Angle to Micro-USB B Right Angle Cable - USB cable - 1 m
Type USB cable
Features 90° connector, right-angled connector, sync and charge, USB On-The-Go
Length 1 m
Connector 5 pin Micro-USB Type B - male
Connector (Second End) 4 pin USB Type A - male
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 1m USB 2.0 A Right...
£5.07
