C2G 1m Value Series™ High Speed HDMI® Cable with Ethernet
£5.65
Select:
40 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Deliver high definition video, audio and Ethernet using a single cable
  • Overall Cable
  • • Drain Wire - 30AWG (07/0.10), Tinned Copper
  • • Foil Shield - Aluminium Foil, 100% Coverage
  • • Braided Shield - 16/4/0.12, Al/Mg
  • • Jacket - PVC, Black, O.D. - 6.0 ± 0.2mm
  • Type: HDMI
  • Length: 1m
  • Stock Status: In Stock
Product codes
The C2G High Speed HDMI with Ethernet Cable is perfect for home theatre or desktop audio video applications requiring high speed HDMI features and video resolutions up to 1080p. The Ethernet capabilities of the cable allow a user to connect multiple Ethernet enabled HDMI devices through a single Ethernet connection. This cable supports bandwidth applications up to 340MHz/10.2 Gbps as well as high speed HDMI features; including, 3D, Deep Colour, x.v.Colour , Dolby True HD, and DTS-HD Master Audio.. This fully-functional, high bandwidth cable is tested to perform at industry standards and is backed by a lifetime warranty.
The new, high speed HDMI with Ethernet cables are compatible with both Sony PlayStation 4 (PS4) and MicroSoft XBOX ONE consoles. They are also backwards compatible with PlayStation 3 (PS3) and XBOX 360
Connector 1: (1) HDMI Male
Connector 2: (1) HDMI Male.
Product Description C2G 1m High Speed HDMI Cable with Ethernet - 4K - UltraHD - HDMI with Ethernet cable - 1 m
Cable HDMI with Ethernet cable
Length 1 m
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - male
Features HDMI Ethernet Channel (HEC), HDMI CEC support (Consumer Electronics Control), moulded
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 1m Value Series™ H...
£5.65
