C2G 20cm DisplayPort Male to HDMI Female Adapter Converter Black
£25.64
39 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Adapt the DisplayPort output of a computer so that it may be connected to a HDTV or projector which accepts a HDMI input
  • Connector 1: (1) DisplayPort Male
  • Connector 2: (1) HDMI Female
  • Length: 20cm
  • Stock Status: In Stock
Product codes
This adapter converter is an ideal solution for adapting the DisplayPort output of a laptop so that it may be connected to a HDTV or projector which accepts a HDMI input. This adapter converter carries a digital audio/video signal, supports up to a 1080p resolution and meets the requirement of high performance applications.
Product Description C2G 20cm DisplayPort to HDMI Adapter - DP Male to HDMI Female - Black - DisplayPort cable - 20 cm
Type DisplayPort cable
Length 20 cm
Connector DisplayPort - male
Connector (Second End) HDMI - female
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 20cm DisplayPort M...
£25.64
