C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter...
C2G 20cm DisplayPort Male to Single Link DVI-D Female Adapter Cable - Black
£19.34
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Adapt the DisplayPort output of a computer so that it may be connected to a computer monitor which accepts a DVI-D input
  • Connector 1: (1) DisplayPort Male
  • Connector 2: (1) DVI-D Single Link Female
  • Length: 20cm
  • Stock Status: In Stock
Product codes
This adapter converter is an ideal solution for adapting the DisplayPort output of a laptop so that it may be connected to a computer monitor which accepts a DVI-D input. This adapter carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
Product Description C2G DisplayPort Male to Single Link DVI-D Female Adapter Converter - video adapter - 20 cm
Type Video adapter
Features Latched
Length 20 cm
Connector DisplayPort - male
Connector (Second End) DVI-D - female
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 20cm DisplayPort M...
£19.34
