C2G 20cm DisplayPort Male to VGA Female Adapter Converter Black
£19.53
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Adapt the DisplayPort output of a computer so that it may be connected to a computer monitor which accepts a VGA input
  • Connector 1: (1) DisplayPort Male
  • Connector 2: (1) HD15 Female
  • Length: 20cm
  • Stock Status: In Stock
Product codes
This adapter converter is an ideal solution for converting the DisplayPort output of a laptop so that it may be connected to a computer monitor which accepts a VGA input. This adapter converter carries an analogue video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
Product Description C2G 20cm DisplayPort to VGA Adapter Converter - DP Male to VGA Female - Black - VGA adapter - 20 cm
Type VGA adapter
Features Latched
Length 20 cm
Connector DisplayPort - male
Connector (Second End) HD-15 (VGA) - female
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 20cm DisplayPort M...
£19.53
