C2G 20M Active HDMI High Speed Cable CL3
£133.15
Select:
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • CL3-rated jacket for in-wall installations
  • Supports up to a 1080p resolution at 60Hz
  • CEC, EDID, and HDCP compatible
  • Length: 20m
  • Stock Status: In Stock
Product codes
The Active High-Speed HDMI cable is the perfect solution for extending HDMI signals in classrooms, conference rooms, boardrooms, and other commercial environments requiring a reliable long-distance connection up to 65 feet (20 metres). The Active HDMI cable features a built-in signal booster that supports HDMI A/V connections at longer distances than non-active cables, allowing you to connect your Blu-Ray player, Laptop, Chromebook or other HDMI device to your HDTV, projector or HDMI-capable display up to 20 metres apart with no signal loss. This cable does not require an external power adapter and supports 1080p resolution at 60 Hz, 3D video, Deep Colour and detailed image display. Additionally, EDID and HDCP are supported for compatibility with HDMI source devices, displays, and content. Combine this active HDMI cable with wall plates for a clean, professional connectivity solution that can be used with projectors in classrooms, conference rooms, or training rooms.
Product Description C2G 20m Active High Speed HDMI Cable In-Wall, CL3-Rated - HDMI cable - 20 m
Cable HDMI cable
Technology Double shielded
American Wire Gauge (AWG) 28
Length 20 m
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - male
Features CL3 rated jacket, HDMI CEC support (Consumer Electronics Control), in wall mounting, HDCP compliant, active converter
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 20M Active HDMI Hi...
£133.15
