C2G 280mm Hook-and-Loop Cable Management Straps - Black - 12pk
£4.12
Delivery:
Key features
  • Each high-strength nylon strap holds about 63.5mm diameter of cables; 12 per package
Product codes
Quickly secure your cable runs for your audio/video equipment stack, computer desk or networking closet. The high-strength nylon-binding strap is easy to use and reuse with its solid nylon buckle and self-attaching, hook-and-loop design.
Product Description C2G Hook-and-Loop cable strap
Product Type Cable strap
Packaged Quantity 12 (specifications are for single item)
Dimensions (WxDxH) 1.9 cm
Length 28 cm
Product Material Nylon
Colour Black
Compliant Standards RoHS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 280mm Hook-and-Loo...
£4.12
