C2G 2m DB37 M/F Extension Cable
£14.30
Delivery:
Standard: 1-3 working days
Key features
  • Extend your DB37 cable for more flexibility
  • Length: 2m
  • Type: Serial
  • Stock Status: In Stock
Product codes
Use DB37 extension cables from C2G for your connection to back up important files from your CPU on a regular basis. Use these cables with your tape back-up or Bernoulli Box applications for reliable data storage and retrieval. The line of extension and replacement cables is fully shielded against EMI/RFI interference, giving you the assurance of quality transmissions every time.
Product Description C2G Extension Cable - serial extension cable - 2 m
Type Serial extension cable
Technology Shielded
Length 2 m
Connector 37 pin D-Sub (DB-37) - male
Connector (Second End) 37 pin D-Sub (DB-37) - female
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 2m DB37 M/F Extens...
£14.30
