C2G 2m DB9 M/F Extension Cable - Beige
£4.46
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Extend your RS-232 serial cable for more flexibility
  • Length: 2m
  • Type: Serial
  • Stock Status: In Stock
Product codes
Don't sacrifice convenience when determining where to place your hardware. A DB9 extension cable can give you the flexibility to extend a computer peripheral wherever you need it. Each extension cable comes fully shielded to prevent unwanted EMI/RFI interference, and the fully snagless cable design delivers excellent strain relief. Connector thumbscrews provide a quick and easy connection every time. All lines are wired straight through.
Product Description C2G Extension Cable - serial extension cable - 2 m
Type Serial extension cable
Technology Shielded
Features Molded, thumbscrews
Length 2 m
Connector 9 pin D-Sub (DB-9) - male
Connector (Second End) 9 pin D-Sub (DB-9) - female
Colour Beige
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 2m DB9 M/F Extensi...
£4.46
