C2G 2m DisplayPort Male to Single Link DVI-D Male Adapter Cable
£28.90
Select:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Connect the DisplayPort output of a computer to the DVI input of a computer monitor
  • Length: 2m
  • Stock Status: In Stock
Product codes
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a DVI-D input. This cable carries a digital video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
Product Description C2G 2m DisplayPort to Single Link DVI-D Adapter Cable M/M - DP to DVI - Black - DisplayPort cable - 2 m
Type DisplayPort cable
Technology Shielded
Length 2 m
Connector DisplayPort - male
Connector (Second End) DVI-D - male
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 2m DisplayPort Mal...
£28.90
