C2G 2m DisplayPort Male to VGA Male Adapter Cable - Black
£10.59
Select:
Delivery:
Standard: 1-3 working days
Key features
  • Connect the DisplayPort output of a computer to the VGA input of a computer monitor
  • Connector 1: (1) DisplayPort Male
  • Connector 2: (1) HD15 Male
  • Length: 2m
  • Stock Status: In Stock
Product codes
This adapter cable is an ideal solution for connecting the DisplayPort output of a laptop to a computer monitor which accepts a VGA input. This cable carries an analogue video signal, supports up to a 1920x1200 resolution and meets the requirements of high performance applications.
Product Description C2G 2m DisplayPort to VGA Adapter Cable - DP to VGA - Black - DisplayPort cable - 2 m
Type DisplayPort cable
Length 2 m
Connector DisplayPort - male
Connector (Second End) HD-15 (VGA) - male
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 2m DisplayPort Mal...
£10.59
