C2G 2m DVI-A Male to HD15 VGA Male Analogue Video Cable
£13.88
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Connect a computer's VGA port to a monitor's DVI-A/DVI-I connector
  • Type: DVI
  • Length: 2m
  • Stock Status: In Stock
Product codes
Digital Visual Interface (DVI) is the standard interface for high-performance connection between desktop PCs and flat panel displays, CRT displays, projectors, and HDTV. This analogue video cable is fully compliant with the DVI standard defined by DDWG (Digital Display Working Group). Three analogue 30 AWG coaxial lines enable high speed analogue transmission
Product Description C2G VGA cable - 2 m
Type VGA cable
Features Colour-coded connectors
Length 2 m
Connector DVI-A - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards PC 99, RoHS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 2m DVI-A Male to H...
£13.88
