C2G 2M HD15 M/M UXGA MONITOR CBL W/ FE
£12.66
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Need high resolution video for your splitter, switch or projector? No problem!
  • Type: UXGA
  • Length: 2m
  • Stock Status: In Stock
Product codes
Go the distance without ghosting and signal distortion. Constructed from premium grade composite coaxial and twisted pair shielded cables, this ultra-premium monitor cable ensures crisp, distortion-free video so you have maximum monitor positioning flexibility. Uses three internal coax lines for red, green and blue. Ferrited to protect against EMI/RFI interference, this double-shielded cable consists of 125% foil shielding and 90% tinned copper braid shielding. Use it for video projectors, video splitters, KVM switches within video presentations, classroom environments, POS devices, server rooms, etc. Will accommodate cable runs up to 100 feet without a booster (in most cases).
Product Description C2G Pro Series UXGA - VGA cable - 2 m
Type VGA cable
Technology Double shielded coaxial
Length 2 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards RoHS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 2M HD15 M/M UXGA M...
£12.66
