C2G 2m HD15 UXGA + 3.5mm Audio M/M Monitor Cable
£15.63
Delivery:
Standard: 1-3 working days
Key features
  • Need great sound AND high resolution video to travel up to 100 feet for your splitter, switch or projector? No problem!
  • Type: UXGA
  • Length: 2m
  • Stock Status: In Stock
Product codes
The Pro Series UXGA monitor cable with 3.5mm audio from C2G is the ideal high performance solution for quickly connecting your PC to a video display system with speakers. Use this cable with projectors, flat-screen monitors, KVM switches with audio, speakers, or a microphone. This cable can support long distances without conditioning the signal. It is ideal for video presentations, projector applications and classroom environments.
Product Description C2G Pro Series UXGA - display / audio cable kit - 2 m
Type Display / audio cable kit
Technology Shielded
Length 2 m
Connectors HD-15 (VGA) - male , Stereo mini jack - male
Connectors (Second End) HD-15 (VGA) - male , Stereo mini jack - male
Compliant Standards RoHS
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 2m HD15 UXGA + 3.5...
£15.63
