C2G 2m UK 17AWG 250V 16 Amp Power Cord BS 1363 to IEC 60320 C19
£8.52
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Power high current IT appliances such as PDUs, PSUs and high powered servers
  • Connector 1: (1) BS 1363
  • Connector 2: (1) C19 IEC
  • Length: 2m
  • Stock Status: In Stock
Product codes
Make your work environment more flexible and efficient. This heavy duty 17AWG cord is designed to work with PDUs, PSUs and other high power devices that use the 3-pin male-to-female shroud power connector. Plus it features a fully moulded design for maximum durability and long life. The female connector plugs directly into the device while the male connector plugs into another power cord, or auxiliary power port on power supply for auto power when the system is turned on.
Product Description C2G 17 AWG 250 Volt 16 Amp Power Cord - power cable - 2 m
Type Power cable
Features Molded
Length 2 m
Localisation United Kingdom
Connector Power IEC 60320 C19
Connector (Second End) Power BS 1363 - male
Rated Voltage AC 250 V
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 2m UK 17AWG 250V 1...
£8.52
