C2G 2m USB 2.0 One B Male to Two A Male Y-Cable
£7.60
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Increase the power running to a portable hard drive from your PC or Mac
  • Length: 2m
  • Stock Status: In Stock
Product codes
Increase the power running to a portable hard drive from your PC or Mac! When a standard USB cable cannot transfer enough power to operate an external device, such as a portable hard drive, you need a USB 2.0 Y-cable. Simply plug this cable's USB B end into the device, and then plug the two USB A ends into open USB ports on one desktop PC or Mac. This cable then pulls power from both USB ports, and thus increases the output to the external drive.
The molded hood on the auxiliary USB A connector enables the user to quickly distinguish between main and auxiliary power. Foil and braid shielding reduces EMI/RFI interference, and twisted pair construction reduces crosstalk for high speed, error-free data transfer. This cable is compatible with USB 1.0, 1.1, and 2.0 specifications.
Product Description C2G "Y" Cable - USB cable
Type USB cable
Technology Double shielded
Features Molded
Connectors 4 pin USB Type B - male
Connectors (Second End) 4 pin USB Type A - male , 4 pin USB Type A (power only) - male
Compliant Standards USB / USB 2.0
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 2m USB 2.0 One B M...
£7.60
