C2G 2m USB 2.0 USB-C to USB-Micro B Cable M/M - Black
£16.11
Delivery:
Key features
  • Connect a USB-Micro B device to a USB Type-C port on a laptop, desktop computer, tablet, or other device
  • Connect the USB-Micro B port of a smartphone, tablet or other mobile device to a USB Type-C port
  • Backwards compatible with USB 2.0 and USB 1.1 devices
  • Length: 2m
Product codes
This USB 2.0 USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port for USB 2.0 communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. The USB Type-C connector is smaller than traditional USB connector and features a symmetrical design which allows it to be easily connected on the first try. Additionally, the durability of the USB Type-C connector allows for up to 10,000 connection cycles. This cable supports a data rate up to 480Mbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
Note: This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
C2G USB-C cable - 2 m
USB-C cable
Sync and charge, colour-coded connectors, nickel plated shell
Length
2 m
Connector
5 pin Micro-USB Type B - male
Connector (Second End)
24 pin USB-C - male
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 2m USB 2.0 USB-C t...
£16.11
