We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
This USB 3.0 (USB 3.1 Gen 1) USB-C to USB-Micro B cable is the perfect solution for connecting a smartphone, tablet, or other device that has a USB-Micro B port to a computer, tablet or other device that has a USB Type-C port up to 2 metres away for USB 3.0 (USB 3.1 Gen 1) communication. The colour-coded USB Type-C connector allows this cable to be easily identified as a USB 3.0 (USB 3.1 Gen 1) cable and differentiated from other cables which may support a different feature set. With its robust design, the USB-C connector can be plugged in and un-plugged up to 10,000 times; six times more than a standard USB A Connector. Additionally, the USB-C connector is user-friendly and has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. This cable supports a data rate up to 5Gbps for data transfer and sync with 5 volts and 1 amp of power for device operation and charging.
Product Description | C2G 2m USB 3.1 Gen 1 USB Type C to USB Micro B Cable - USB C Cable Black - USB-C cable - USB-C to Micro-USB Type B - 2 m | Type | USB-C cable | Features | Sync and charge, colour-coded connectors, nickel plated shell | Length | 2 m | Connector | 24 pin USB-C - male | Connector (Second End) | 10 pin Micro-USB Type B - male | Compliant Standards | USB 3.0/ USB 3.1 | Colour | Black | Manufacturer Warranty | Limited lifetime warranty |
General | |
American Wire Gauge (AWG) | 24/30 |
Plated Connector | Gold |
Length | 2 m |
Colour | Black |
Connectivity | |
Miscellaneous | |
Dimensions & Weight (Shipping) | |
Service & Support | Limited lifetime warranty |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
