C2G 3.7m (12ft) USB C to DisplayPort Adapter Cable 4K - Black
£49.51
Delivery:
Notify me
Key features
  • Connect a USB-C computer directly to the DisplayPort input of a projector or display to transmit video and audio
  • Length: 3.7m
Product codes
Experience 4K ULTRA HD displays with this USB-C to DisplayPort Adapter Cable which provides a fast and reliable connection between a USB Type C enabled Chromebook, laptop, tablet, smartphone or other device, and the DisplayPort input of a projector or display – making it an ideal solution for the office, work space applications or classrooms. This adapter utilises the audio/video capabilities built into USB Type-C ports to feed an audio/video signal to a DisplayPort monitor to achieve high quality, 4K (ULTRA HD) video image. Additionally, the USB-C connector has a symmetrical design which is identical on both sides, which means it does not matter if you plug it in upside-down or right-side-up - it will plug in the first time, every time, whilst preventing damage to the connector port. The cable form factor of this adapter provides a simple and convenient solution that eliminates the need for a separate adapter or additional cabling, offering a straightforward installation.
Product Description C2G 3.7m (12ft) USB C to DisplayPort Adapter Cable Black - 4K Audio / Video Adapter - external video adapter - black
Device Type External video adapter
Bus Type USB-C
Max Resolution 3840 x 2160
Interfaces DisplayPort (male connector)
Length 3.7 m
Enclosure Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£49.51
Notify me
