This OM3 Duplex Multimode Fibre Optic Cable is ideal for connecting 10GBase-SR, 10GBase-LRM, SFP+ and QSFP+ transceivers for 10 gigabit network connections. This cable has a LSZH jacket which protects from toxic and corrosive gases in poorly ventilated spaces and other areas where it is most critical. This cable also provides backward compatibility with existing 50/125 equipment and the performance headroom required to support LED and VCSEL laser light sources, and 10 Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures.
Product Description | C2G SC-SC 10Gb 50/125 OM3 Duplex Multimode PVC Fiber Optic Cable (LSZH) - network cable - 30 m - aqua | Type | Network cable - OM3 | Technology | Fibre optic | Type of Fibre Optics | Multimode | Features | Halogen-free | Length | 30 m | Core / Cladding Diameter | 50 / 125 micron | Connector | 2 x SC multi-mode - male | Connector (Second End) | 2 x SC multi-mode - male | Colour | Aqua | Manufacturer Warranty | Limited lifetime warranty |
General | |
Network Cable Type | Network cable - OM3 |
Jacket Material | Low Smoke Zero Halogen (LSZH) |
Fibre Qty | 2 |
Length | 30 m |
Colour | Aqua |
Connectivity | |
Miscellaneous | |
Compliant Standards | TIA/EIA-455-171A |
Manufacturer Warranty | |
Service & Support | Limited lifetime warranty |
Environmental Parameters | |
Min Operating Temperature | -20 °C |
Max Operating Temperature | 70 °C |
