C2G 30m SC-SC 9/125 OS1 Duplex Singlemode PVC Fibre Optic Cab...
C2G 30m SC-SC 9/125 OS1 Duplex Singlemode PVC Fibre Optic Cable (LSZH) - Yellow
£38.00
Delivery:
Key features
  • Connector 1: (1) SC Male
  • Connector 2: (1) SC Male
  • 9/125 micron cable for Gigabit Ethernet applications where protection from toxic and corrosive gases is critical
  • Low Smoke Zero Halogen (LSZH / LS0H) jacket
  • Each cable is 100% optically inspected and tested for insertion loss before you receive it
Product codes
Cost-effective solution that provides high bandwidth and transmission rates over longer distances. With SC to SC termination, this high quality fibre optic patch cable is specifically designed for Gigabit Ethernet applications. The Low Smoke Zero Halogen (LSZH / LS0H) jacket is composed from materials that lessen the smoke and halogen emissions when the cable is exposed to extreme temperatures. This reduces the amount of harmful toxic and corrosive gases that cabling made with plastic materials would otherwise emit into the air during combustion. This construction makes LSZH cables ideal for use where the protection of people and equipment from harmful corrosive gases is absolutely critical. The patented injection moulding process provides each connection greater durability in resisting pulls, strains and impacts from cabling installs. Each cable is 100% optically inspected and tested for insertion loss before you receive it. A pull-proof jacket design surrounds the popular 9/125 Single-mode fibre, immune to electrical interference.
Product Description C2G SC-SC 9/125 OS1 Duplex Singlemode PVC Fiber Optic Cable (LSZH) - patch cable - 30 m - yellow
Type Patch cable - OS1
Technology Fibre optic
Type of Fibre Optics Singlemode
Features Halogen-free
Length 30 m
Core / Cladding Diameter 9 / 125 micron
Connector 2 x SC single-mode - male
Connector (Second End) 2 x SC single-mode - male
Colour Yellow
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 30m SC-SC 9/125 OS...
£38.00
