C2G 3ft C14 to C19 250v 14AWG
£13.21
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Power a server or connect a PDU in a data center or network wiring closet
  • Supports up to 250 Volt and 15A connections
  • 14AWG conductor construction
  • Designed for use in a data center or network wiring closet
  • Length: 91.4cm
  • Stock Status: In Stock
Product codes
This power cord is the ideal solution for powering a server or connecting to a PDU in a data center or network wiring closet. This cable is able to support up to 250 volt connections and features 14AWG condutor construction. The fully molded design provides for maximum durability and long life.
Product Description C2G 14 AWG 250 Volt Power Cord - power cable - 91.4 cm
Type Power cable
Features Molded
Length 91.4 cm
Connector Power IEC 60320 C19
Connector (Second End) Power IEC 60320 C14
Rated Voltage AC 250 V
Rated Current 15 A
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 3ft C14 to C19 250...
£13.21
