C2G 3m USB 2.0 A/B Cable - White
£4.56
Select:
More than 50 in stock
Delivery:
Standard: 3-5 working days
Key features
  • Connect your USB device to the USB port on your USB hub, desktop PC or Mac
  • Length: 3m
  • Stock Status: In Stock
Product codes
USB A/B cables from C2G are designed to connect from the USB port on your hub, PC or Mac to your USB device. This fully-rated USB cable provides transfer rates up to 480 Mbps, and easily attaches to any USB device. This cable is compatible with USB 1.0, 1.1 and 2.0.
Product Description C2G USB cable - 3 m
Type USB cable
Technology Double shielded twisted pair
Length 3 m
Connector 4 pin USB Type A - male
Connector (Second End) 4 pin USB Type B - male
Compliant Standards USB / USB 2.0
Colour White
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 3m USB 2.0 A/B Cab...
£4.56
