C2G 3m USB 2.0 A Male to Micro-USB B Male Cable
£10.56
Delivery:
Key features
  • Connect your portable USB device to a micro-USB port on your computer or other USB device
Product codes
Connect to mobile phones, GPS systems, PDAs, OTG devices and digital cameras by using the micro-USB connection on your computer or other USB device. The micro-USB connector is smaller and thinner than the previous USB Mini-b standard while offering better performance. Its small form factor is ideal for today's compact portable devices while easily transferring data or charging your device at a transfer speed up to 480 Mbps. This cable is compliant with USB 2.0 specifications and the On-The-Go supplement.
Product Description C2G USB 2.0 A to Micro B Cable - USB cable - 1 m
Type USB cable
Length 1 m
Connector 5 pin Micro-USB Type B - male
Connector (Second End) 4 pin USB Type A - male
Compliant Standards USB 2.0 On-The-Go
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 3m USB 2.0 A Male...
£10.56
