C2G 3m USB 2.0 A to Mini B Cable
£4.75
30 in stock
Delivery:
Standard: 1-3 working days
Key features
  • An ultra-premium, high-performance cable to connect your USB Mini-B device to the USB port on your USB hub, PC or Mac
  • 24k gold-plated connectors provide maximum corrosion resistance
  • This cable will deliver high speed data transfer up to 480 Mbps
  • Two 24 AWG and two 28 AWG heavy duty wires provide the proper current to your USB device
  • Stock Status: In Stock
Product codes
The Ultima USB cable optimizes style, quality, and value in a cable specially designed for high performance. Just plug-and-play for USB devices with the mini-b port, and this cable will deliver high speed data transfer up to 480 Mbps. Two 24 AWG and two 28 AWG heavy duty wires provide the proper current to your USB device. Dual foil and braid shielding reduces EMI/RFI interference while twisted pair construction helps reduce crosstalk thus ensuring high speed, error-free data transfer. The sleek design of the molded connectors makes them easy to grip. The metal connector shield helps to meet FCC requirements on EMI/RFI interference, while a solder-to-connector shell and cable braid create an end-to-end shielding solution for a noise-free connection. 24k gold-plated connectors provide maximum corrosion resistance for error-free data transfer. The charcoal gray cable jacket not only matches your case but disappears behind your desk leaving a clean organized look. Finally, an ultra-flexible jacket makes installation easy.
Product Description C2G Ultima 3m USB 2.0 A to Mini-B Cable (9.8ft) - USB cable - 3 m
Type USB cable
Technology Double shielded twisted pair
Features Molded, EMI/RFI protection
Length 3 m
Connector 4 pin USB Type A - male
Connector (Second End) Mini-USB Type B - male
Compliant Standards USB / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 3m USB 2.0 A to Mi...
£4.75
