C2G 3m USB 2.0 USB C to USB A Cable M/M – Black
£17.31
Select:
Delivery:
Key features
  • Provides compatibility for USB-A laptop, tablet, or desktop to connect to a USB-C mobile phone, tablet, printer or external hard drive
Product codes
This USB 2.0 USB-A to USB-C cable is the perfect solution for connecting a smartphone, tablet, or other device with a USB-C port to a computer with the standard a USB Type-A port up to 3 metres away for USB 2.0 communication. This cable supports a data rate up to 480Mbps for syncing and downloading pictures or uploading new apps, as well as 5 volts and 1 amp of power for device operation and charging. The USB-C connector has a robust design allowing for the connector to be plugged in and un-plugged up to 10,000 times; six times more connection cycles than traditional USB A connectors. Additionally, the USB-C connector is user-friendly has a symmetrical design which is identical on both sides, meaning it does not matter if you plug it in upside-down or right-side-up. It will plug in the first time, every time, whilst preventing damage to the connector port. The colour coded USB Type-C connector allows this cable to be easily identified as a USB 2.0 cable and differentiated from other cables which may support a different feature set. This cable is designed to support USB 2.0 communication and features and is not able to support USB 3.1 Gen 2 Communication and features.
Product Description C2G 3m USB 2.0 USB Type C to USB A Cable M/M - USB C Cable Black - USB-C cable - 3 m
Type USB-C cable
Technology Double shielded
Features Molded, sync and charge, nickel plated shell
Length 3 m
Connector 4 pin USB Type A - male
Connector (Second End) 24 pin USB-C - male
Compliant Standards USB / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
C2G 3m USB 2.0 USB C t...
£17.31
